Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Computer problem
1988 Other Subaru Models 4 cyl Four Wheel Drive Manual 123000 miles
Motor ran fine then had trouble starting then it started the next time I switched off it would not start again.
I found out there was no spark to the plugs but there was power to the coil.There is no power going to the distributor(Electronic) Tried a used distributor and ECM
Okay, to help you best I am going to need your specific model…..please be specific as there are several 4WD choices. Next, please give me your specific engine size in liter and the 8th digit of our VIN.
Once I get this info…we can jump right into checking a few things……
Thanks for the donation
Find a car repair manual for your car repair questions.
Computer problem
The Engine is 1800 OHV SPFI
The 8th Vin Digit is B Thanks Roy
Computer problem
The pugs are new,The wires about a year same as cap and rotor.
The thing is there is no power going to the distributor
whe wire seems to be from the firewall area.The test sheet you sent is to faint to read.Roy
check ecm terminal 17 and 9 for voltage also check coil it suplies spark to dist. here is wiring diagram I also emailed the tests and wiring diagram to you for better seeing check your grounds to and from also fuse #11
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
