1988 Other Mitsubishi Models Engine dies when put in drive o
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Performance problem
1988 Other Mitsubishi Models 4 cyl Four Wheel Drive Automatic 150000 miles
1988 Mitsubishi Mighty Max Truck 2.6L,4x4,Auto,Carb
I bought this truck in this condition.
The engine dies when put in drive. It does not do it
when the engine is cold.
The previous owner went around the neutral switch
so a person could start and take-off while in gear.
Once on the highway the truck runs o.k.However
Whenever you slow down the engine will die unless
you put the gearshift in L2.And if you slow further
down you have to go to L1 or the engine will die.
The truck is a little weak while driving.Sometimes
when the truck is in neutral the engine will die
for no apparent reason.
The engine was supposed to be rebuilt a while back
The oil pressure is good.
There is no air filter or housing.
The Ignition timing is o.k. I also changed the
ignition coil
I pulled the spark plugs out. 2 plugs had black soot
on them. 2plugs were o.k. (brownish white)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
