Auto Repair Talk - Ask a Question, Get a FREE Answer.
Go Back
1988 Other Mercedes Benz Models Engine Overherheating
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Sat Nov 22, 2008 2:31 pm |
By
tangyanikar,
Likes cars! |
Give Feedback | Votes: 0 |
1988 Other Mercedes Benz Models 6 cyl Two Wheel Drive 97767 miles
I got a partial valve job and a head gasket replacement. after a week or two I decided that I was chilly and needed to use the heat. The car began to overheat, up to 120, but as long I I didn't sit and idle I could make the Temp reduce.
Well the other day, the Temp went above 120, and since then,it won't reduce no matter if I drive or what. It now shuts off. It is no longer my happy little car. It makes a smell and shudders off... However, the oil is not milky, nor is there water in it. Nor is there smoke or any other typical signs of a blown gasket. BUT, the radiator is cold and the engine is hot.
What in tarnation is going on? I would give $$ but I have given it all to this mechanic, who has run out of Ideas. I think that there is sludge in the line and no fluid is going to the radiator from the water pump IF that is even working.
| Find a
car repair manual for your Other Mercedes Benz Models. |
Posted at Sat Nov 22, 2008 4:36 pm |
By
tangyanikar,
Likes cars! |
how much does it cost, ballpark, for radiator flush and cleaning?
| Find a
Posted at Mon Nov 24, 2008 11:20 am |
By
tangyanikar,
Likes cars! |
I filled the radiator with H20 and now the radiator cools the engine as long as the car moves and doesn't have to idle in traffic . The only problem is that I live in Los Angeles, engine idle capital of the world. After filling the radiator does this mean that the radiator is working or does this mean that the radiator is still part of the circulation problem as it still only works when in transit? Where else could the circulation problem be?
| Find a
By
tangyanikar,
Likes cars! |
| Find a
Posted at Mon Nov 24, 2008 11:25 am |
By
tangyanikar,
Likes cars! |
By the way the thermostat is new.
Why is it that I can't use the heat in my car. In other models, when the car was overheating, turning on the heat was a surefire way to lower the engine temp.
It is cold here in the morning and I want to use my heat. The last time I used the heat the engine temp soared, why did that happen?
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
