Steering problem
1988 Other BMW Models 6 cyl Two Wheel Drive Automatic oooooo miles
I ran into a problem figuring out how to change my steering column due to the fact that the bolts that hold the top of the unit are jammed up in the dash.Can I change the column without having to undo my whole dash?
The fracture bolts need to be removed. They are a pain in the *bad word*. You might be able to chisel them out or drill them. It is difficult to describe, but, you should not need to remove the dash cap
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
