Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
1988 Mercury Tracer 4 cyl Front Wheel Drive Automatic 91,000 miles
On my 1988 Mercury Tracer wagon, it makes a loud pinging noise when you accelerate when the engine is hot. IT does not do it when it is cold but it is very loud when it is hot and it only happens when accelerating. Any ideas ???
The pinging is caused when the fuel mixture ignites prematurely and put extreme stress on the mechanical parts of the engine.
This can sometimes be caused by a bad tank of gas. You want to fix this problem quickly, otherwise you can cause severe engine damage.
Have the mechanical timing checked, this is done by going into diagnostic mode and setting the base timing by adjusting the distributor.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
