Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
1988 Mazda 323 4 cyl Front Wheel Drive Manual 198000 miles
How do I match up timing when I change timing belt I can see the mark on top but not on the bottom which is the camshaft. The car starts but won't run the best so I 'm guessing the timing is off. Please help.
I see the mark for the cylinder head but on the crankshaft I don't see the mark on sprocket what kind of mark is on the spocket & also the car did start but it's hard to start it's like it flooding out is that because it 's to far advanced.
Not exactly sure the marking on the sprocket. However, the keyway that keeps the spocket from spinning should be straight up. If the spocket has a backing plate attached to it look on it for the mark it.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
