Free Auto Repair Advice by Certified ASE Technicians
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1988 Jeep YJ Ignition Lock Cylinder
Posted at Mon Jun 22, 2009 12:39 pm |
By
Jeepin Jimmy,
New to the forum |
Give Feedback | Votes: 0 |
Steering problem
1988 Jeep YJ 6 cyl Four Wheel Drive Manual 148000 miles
My son is out in Colorado going to the AF Academy. He bought an 88 YJ from his younger brother and is trying to replace the ignition lock cylinder. Is there a retaining screw under the turn signal switch assembly in the column that holds the Ignition Lock cylinder in place? I am a mechanic and own my own shop but haven't been inside a Jeep steering column before unfortunately? |
Find a
car repair manual for your Jeep YJ Repair Question.
Posted at Mon Jun 22, 2009 12:55 pm |
By
bluelightnin6,
Certified 2CarPros Technician |
            (6723) Give Feedback | Votes: 227 |
Assuming he does have a key and the Jeep does not have airbags, perform the following operations to remove the lock cylinder..
REMOVAL:
Remove the turn signal switch.
Insert the key in the lock cylinder and turn it to the ON position.
Remove the key warning buzzer switch and contacts AS AN ASSEMBLY using needle-nosed pliers, or a paper clip with a 90° bend.
NOTE:
Some steering columns may have a retaining screw holding the lock cylinder in the column. When servicing this type, simply remove the retaining screw and remove the lock cylinder.
With the ignition switch still in the ON position, insert a thin screwdriver into the slot adjacent to the switch attaching screw boss (right-hand slot). Depress the spring latch located at the bottom of the slot to release the lock cylinder.
Remove the lock cylinder
INSTALLATION:
To install the lock cylinder, turn the key to the LOCK position. Insert the lock cylinder in to the housing far enough to contact the drive tang. Force it inward and move the ignition switch actuator rod up and down to align the components. When the components align, the cylinder will move inward and the spring-loaded retainer will snap into place locking the lock cylinder in the housing.
If the lock cylinder is retained by a screw, tighten the screw to 40 inch lbs. (5 Nm).
Install the key warning buzzer switch.
Follow the ignition switch installation procedures to adjust the ignition switch.
Install the turn signal switch. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
