Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1999 Lincoln Town Car E...
Auto Repair1997 Chrysler Sebring S...
Auto Repair1995 Ford Explorer Stay...
Auto Repair1997 Nissan Maxima No S...
Auto Repair2001 Hyundai Santa Fe C...
Auto Repair2000 Chevy Monte Carlo ...
Auto Repair1977 Cadillac Deville D...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1988 Jaguar XJS Engine Runs but not enough power to move th
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Wed Nov 19, 2008 5:57 am
By Bob8971, Have Donated
Give Feedback | Votes: 0
Engine Performance problem
1988 Jaguar XJS V12 Two Wheel Drive Automatic 39000 miles
I have a 1988 Jaguar Xjs convertable. Reciently during a trip 10 mile trip it started losing power and I almost didn't get back home. The last mile or so max speed uphill was 3 or 4 mph. I can get the engine to run but not enough power to move up the 10 degree slop of my driveway.
The fuel pump is opperating but I didn't check pressure. Lots of exhaust ( Cat Convert not clogged). Replaced the fuel filter.
Any suggestions?
Find a car repair manual for your Jaguar XJS Repair Question.
Posted at Wed Nov 19, 2008 3:52 pm
By James R. Weizel, Moderator
Reputation: 138.3Reputation: 138.3Reputation: 138.3Reputation: 138.3Reputation: 138.3Reputation: 138.3Reputation: 138.3 (138) Give Feedback | Votes: 8
Does it pop and spit or is it like there is no throttle response? Also, is it the same in neutral as it is in drive? Please advise.
Posted at Thu Nov 20, 2008 7:18 am
No, it does not pop and spit. It takes a while to start but once started with the transmission in park and with the gas peddle depressed perhaps 1/2 way to the floor, the engine starts to accelerate and after about 3, 4 or 5 seconds the RPM's are high enough that I'm not comfortable with the high engine speed so I release the gas peddle. The engine doesn’t stall and I can repeat the above. If I start the engine then put the transmission in drive, there is not enough power to move the car and the engine stalls.
I don't know if the following is related but prior to this problem I experience the following issue. Upon startup I would place the trans in drive, depress the accelerator and the engine would not accelerate. I would quickly press then release the gas peddle 5 or 6 times then the engine would accelerate. I would have to repeat the process each time I wanted to accelerate away from a stop sign or red light until I had driven perhaps 1 mile. After that, the engine would perform normally.
Posted at Thu Nov 20, 2008 7:21 am
I forgot to mention. The coil produces a good strong spark
Posted at Sat Nov 22, 2008 8:49 am
Your last paragraph was very helpful. I have to believe, by what you have posted, the air flow meter is the culprit. This unit senses how much air the engine is calling for and tells the computer to adjust the fuel accordingly. if the AFM thinks you are still at an idle, no matter how much throttle you give the engine, it doesn't increase the fuel. A new AFM is big bucks. I have an '88 XJ6, but have never had your problem. When I have a high dollar problem with mine, I'm not afraid of used parts. Pricewise, it doesn't hurt quite so bad if it doesn't fully solve my problem. I use a company on the internet called URG autoparts. Here you can get a list of the salvage yards accross the US. that have the part you are looking for and for how much. Their web address is; "www.urgpartsearch.com/searchframe.cfm". At this site you can find almost anything you want for your car. Hope this helps.
Posted at Mon Nov 24, 2008 12:09 pm
Thanks for your reply. However, my Jag doesn't have an Air Flow Meter/Mass Flow Sensor.
Do you think it could be the the ECU (Engine Control Unit) Computer.
Posted at Wed Nov 26, 2008 8:28 am
Your right. '88 XJ6 used a meter, XJS didn't. Your air/fuel mixture is controlled by the throttle position sensor. This could cause a the ECM to think you are not accelerating and thusly, not giving the engine any fuel. This unit is located on the throttle body with a microswitch that turns the cold start injectors on/off when needed. Do you have any VCM codes stored in memory? This also could be a clue.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
