Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
1988 Ford F250 V8 Two Wheel Drive Automatic
I just can't find the correct way to get this installed. If you could send some information regarding this issue, it would be greatly appreciated. It is a 1988 Ford F250. The motor is a size 302. 2 Wheel drive with a V8 Engine. Pictures would also be great if you could send those along with it....
Remove distributor
Put the engine no. 1 piston on its compression/TDC-make sure timing marking O/pointer are align on the damper. Now set the distributor in making sure the rotor is pointing to the no.1 cap tower.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
