1988 Ford E-Series Van replacement with long block
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
1988 Ford E-Series Van V8 Two Wheel Drive Automatic 91000 miles
cylinders 3 and 4 do not create enough compression (60 lbs). to repair might create to much bottom stress for lower parts - or will it if i do a passenger head job?
460 cid efi
Find a car repair manual for your Ford E-Series Van Repair Question.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
