Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
1988 Ford Bronco 6 cyl Four Wheel Drive Manual
what kind of price do you think it would cost to fix our bronco2 it has a blown head gasket so were gonna switch engines with another bronco2 then ours will also need some plate on top the transmission because our shifter can move all the way horizontal when going from fourth to drive. we are also going to put in a new clutch and clutch plate to be on the safe side! what do you think on an estimate that would cost us???????
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
