Welcome to our question and answer forum where over 6,000
free auto repair questions are answered every month,
after you have completed our free signup you will able
to ask a question and receive an answer from one of our
many forum members.
If you elect to donate any small amount of money we will
assign one of our 2CarPros Certified Repair
Technicians to answer your question. Questions
with donations are answered promptly and 100% of the
donation is awarded to the technician helping you.
Engine Performance problem
1988 Dodge Dakota 6 cyl Four Wheel Drive Manual 98000 miles
My engine is idling rough and it runs rough when you first step on the gas.Almost like its choking. It runs fine when your driving but when you first start it and at any stopand go. I changed the wires and plugs-put a new distributer in because of play. A new throttle position senser.
Don't get it! Hope you can help.
Maybe your carburator is leaking at the gaskets, thats what happened to mine. But don't touch that needle that can only be turned with an allan key. You will see it after you remove the top plate of the carburator. Or try the Electronic control module its located by the glove compartment around there. Or it could be the throttle position sensor.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
