Car Repair Chat - Ask a Question, Get a FREE Answer.
Go Back
1988 Chevy S-10 Vent Control Problem with '88 S10 Chevy Bla
Welcome to our question and answer forum where over 6,000
free auto repair questions are answered every month,
after you have completed our free signup you will able
to ask a question and receive an answer from one of our
many forum members.
If you elect to donate any small amount of money we will
assign one of our 2CarPros Certified Repair
Technicians to answer your question. Questions
with donations are answered promptly and 100% of the
donation is awarded to the technician helping you.
Watch our new
Car Repair Video Series
with Ken Lavacot.
Posted at Wed Jul 02, 2008 5:05 pm |
By
jbil,
Likes cars! |
Give Feedback | Votes: 0 |
Heater problem
1988 Chevy S-10 6 cyl Four Wheel Drive Automatic 160,00 miles
The heater/AC on my '88 S10 Chevy Blazer blows hot/cold air well. However, when I adjust the selector to any of the AC choices, the air only blows on the floor rather than
the dash vents.
I've checked to see that the 2 vacuum hoses are connected to the heater/AC diaphragm on the floor. Maybe the other ends aren't connected.
Questions
1. Could this be the reason that the baffles don't adjust to bring the air to the dash vents?
2. If so, is there a diagram showing their location on the other side of the firewall?
3. Is there a handy "how to" cheat sheet to disassemble/reassemble the heating/AC system if it turns out that the diaphragm is bad?
My Chilton manual is lacking any information on how to troubleshoot this problem,
Thanks a million,
Jbil
| Find
diagnostic tools,
replacement parts
or locate a
car repair manual for your Chevy S-10 Repair Question. |
Posted at Thu Jul 03, 2008 7:55 pm |
By
SWilliams,
Tech level 3 |
(7) Give Feedback | Votes: 0 |
Does it do the same thing if you select the defrost or dash vents while in heater mode? Do you hear any hissing from the control panel area while in A/C mode?
| Find
diagnostic tools,
replacement parts
or locate a
Posted at Fri Jul 04, 2008 1:58 am |
By
jbil,
Likes cars! |
| SWilliams wrote: | | Does it do the same thing if you select the defrost or dash vents while in heater mode? Do you hear any hissing from the control panel area while in A/C mode? |
No hissing sound heard. And air blows to defrost and floor regardless of selection.
| Find
diagnostic tools,
replacement parts
or locate a
Posted at Fri Jul 04, 2008 12:14 pm |
By
SWilliams,
Tech level 3 |
Ok, Open the hood and look for a vacuum line that runs back to the dash. Follow that line and see if it is split/cracked or disconnected. That line feeds the control panel. It goes to a T in the line that connects to the vacuum reservoir. That reservoir has a check valve in it that may have failed. Follow the other line off the reservoir back to the engine, it will connect to a port on the intake manifold. That is the same line that actuates the 4X4 as well. So check that mess of vacuum lines for a leak as well.
| Find
diagnostic tools,
replacement parts
or locate a
Posted at Mon Jul 07, 2008 5:40 am |
By
jbil,
Likes cars! |
| SWilliams wrote: | | Ok, Open the hood and look for a vacuum line that runs back to the dash. Follow that line and see if it is split/cracked or disconnected. That line feeds the control panel. It goes to a T in the line that connects to the vacuum reservoir. That reservoir has a check valve in it that may have failed. Follow the other line off the reservoir back to the engine, it will connect to a port on the intake manifold. That is the same line that actuates the 4X4 as well. So check that mess of vacuum lines for a leak as well. |
Thanks for the tip. I'll be checking the line in the next couple days.
| Find
diagnostic tools,
replacement parts
or locate a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
