Free Auto Repair Advice by Certified ASE Technicians
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1988 Chevy Blazer Truck won't start.
Posted at Sat Nov 29, 2008 1:21 pm |
By
Andyman78,
Have Donated |
Give Feedback | Votes: 0 |
Electrical problem
1988 Chevy Blazer V8 Four Wheel Drive Automatic 68000 miles
My Blazer won't start. When I turn the key, the battery gauge dives all the way down and the engine turns over just a few degrees, but doesn't continue to rotate. I've had the battery charged and tested. They said it was ok. I've had the starter tested, they said it was ok. I jumped the terminals on the starter and got the same outcome. I have 12 volts at the main power wire on the starter and a test light dimly lights up on the signal wire to starter. What do I check next? What's not working the way it should? |
Find a
car repair manual for your Chevy Blazer Repair Question.
Posted at Sat Nov 29, 2008 3:00 pm |
By
Jacobandnickolas,
Certified 2CarPros Master Technician |
                              (15694) Give Feedback | Votes: 122 |
Hi:
When you had the battery tested, was it load tested? It sounds like there may be 12 volts at the battery but when there is a load on it, it shorts out internally. Also, make sure the battery terminals are clean and tight and the ground on the engine block is clean, tight, and there are no breaks in the cable from corrosion.
Joe |
Find a
Posted at Sun Nov 30, 2008 11:20 am |
By
Andyman78,
Have Donated |
The truck does the same thing when I try to jump start it. They should exclude the battery from being the problem, right?
The ground I'm checking should go from the battery to the engine block, right?
What tests can I do with my multimeter to verify the condition of the power wire to the starter? Continuity and proper voltage? Anything else? |
Find a
Posted at Sun Nov 30, 2008 10:12 pm |
By
Jacobandnickolas,
You can't exclude the battery unless it passed a load test. It could read 12+ volts then die under a load.
As far as the ground, yes the one to the engine block and any you find on the body.
As far as the multimeter, I need you to check voltage. There should be two wires at the starter, a large one and a small one. The large one will have 12 volts, but the small one should only get 12 volts when the key is in the start position.
Let me know how it goes.
Joe |
Find a
Posted at Tue Dec 02, 2008 2:46 pm |
By
Andyman78,
Have Donated |
My battery tester says that the battery is ok. It tested it at 850 cca and it read 570 cca. It said it needs to be charged, but it's ok.
I checked the grounds that I could find and don't see any thing wrong.
I'll check the starter wires tomorrow when I have a helper. |
Find a
Posted at Tue Dec 02, 2008 5:09 pm |
By
Jacobandnickolas,
Hi again:
When you tested the battery, did you use a specific gravity tester or an actual load tester? Let me know what you find with the starter.
Joe |
Find a
Posted at Wed Dec 03, 2008 4:59 pm |
By
Andyman78,
Have Donated |
Just a load tester. No specific gravity.
I put a multimeter on the signal wire to the starter and I think i only saw 3 volts when I turned the key. |
Find a
Posted at Wed Dec 03, 2008 7:10 pm |
By
Jacobandnickolas,
Hi:
If thats all your getting, either the cable is bad, you have a bad ground, a bad starter relay, or the ignition switch is bad. I would start with the easiest. If you check under the hood in the power distribution center, see if there is an exact match for the starter relay and switch it to see if that helps.
Joe |
Find a
Posted at Sun Dec 14, 2008 3:16 pm |
By
Andyman78,
Have Donated |
The weather was nice today, so I got out there and found out there's a bad ground somewhere. I put a jumper cable from a starter bolt to the neg. terminal on the battery and it turned right over.
I then cleaned the connections on the neg. terminal and the ground cables to the block and the body. I checked those ground cables for continuity and didn't see any trouble. But it still won't start without the jumper cable. Is there another ground cable that I should look for or inspect?
Thanks so much for your help with this! |
Find a
Posted at Mon Dec 15, 2008 6:59 am |
By
Jacobandnickolas,
Hi:
If you need to ground from the battery to the starter for it to start, you may just want to run a new seperate ground to the starter. There must be corrosion where the starter bolts and you're not getting the ground you need. Either remove the startrer, clean mounting surface, and replace starter to see if that works, or just bolt a new ground to one of the mounting boltes. Make sure the wire you use is as heavy as the one going to the battery.
Joe |
Find a
Goto page 1, 2 Next
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
