Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1999 Ford Escort Noise ...
Auto Repair1993 Ford F150 !993 For...
Auto Repair1995 Lincoln Town Car H...
Auto Repair1997 Dodge Neon Which 0...
Auto Repair1987 Ford F150 Spark Plugs
Auto Repair1991 Isuzu Amigo Won't ...
Auto Repair1994 Ford Ranger 94 Ran...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1988 Buick Century crankshaft sensor
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Mon Oct 13, 2008 4:26 am
By dburgette, Have Donated
Give Feedback | Votes: 0
Electrical problem
1988 Buick Century 6 cyl Two Wheel Drive Automatic 50000 miles
The crankshaft position sensor went bad on my 88 Buick century with a 3.8 engine. I replaced the sensor and the car started up and ran fine. After turning the car off it will not start. I ohmed the sensor to find the sensor was bad. Purchased another sensor and after installation did the same thing. Car ran fine until turned off. I was very careful on the second install to make sure sensor was not getting hit by the fins. Could the sensor be getting to high of a voltage or could I be getting the wrong sensor? Any suggestions on what I should check?
Find a car repair manual for your Buick Century Repair Question.
Posted at Mon Oct 13, 2008 6:20 am
By KHLow2008, Moderator
Reputation: 141.7Reputation: 141.7Reputation: 141.7Reputation: 141.7Reputation: 141.7Reputation: 141.7Reputation: 141.7 (142) Give Feedback | Votes: 14
Hi dburgette,
Hope the following explains the installation process.
CRANKSHAFT SENSOR
Removal
1. Disconnect crankshaft sensor harness connector.
2. Position harmonic balancer so that window in interrupter ring is lined up with sensor. Loosen sensor retaining bolt until sensor is free to slide in pedestal. Remove pedestal mounting bolts. Carefully remove sensor and pedestal as an assembly.
Installation
1. Loosen bolt on pedestal until sensor is free to slide in pedestal. Verify that window in interrupter ring is properly positioned. Install sensor and pedestal as an assembly. Install and tighten pedestal mounting bolts.
2. Rotate harmonic balancer until interrupter ring fills sensor slot and edge of window is aligned with edge of deflector on pedestal. Insert Crankshaft Position Sensor Adjuster (J-36179) into gap between sensor and each side of interrupter ring.
3. If gauge will not slide past sensor on either side of ring, sensor is out of adjustment or interrupter ring is bent. Check clearance at 3 positions around outer interrupter ring (about 120 degrees apart).
ADJUSTMENTS
CRANKSHAFT SENSOR
1. Loosen bolt on sensor pedestal and insert Position Sensor Adjuster (J-36179) into gap between sensor and interrupter on each side of ring. See Fig. 3 .
2. Make sure interrupter is sandwiched between blades of adjuster and both blades are properly inserted into sensor slot. Tighten sensor while maintaining light pressure on sensor.
3. A clearance of .025" (.64 mm) is required on either side of interrupter ring. Check clearance at 3 positions around outer interrupter ring (about 120 degrees apart). If interrupter ring contacts sensor at any point during harmonic balancer rotation, the interrupter ring is bent and must be replaced.
© 2007 Mitchell Repair Information Co., LLC.
IGNITION SYSTEM - C3I (FWD) -1988 Buick Century Custom 10/13/2006
http://www.ondemand5.com/mric/common/asp/printart.aspx
Posted at Mon Oct 13, 2008 6:29 am
The instructions you sent are just what i did twice. The sensor does not come in contact with the fin in the balancer. The problem is after i start the car and let it run for a few minutes the sensor goes bag. I have removed the sensor to check for marks from contact with the fin and there are no marks. I measuered the fins with a dial indicator and the are not bent. What voltage reading should i get at the sensor plug?
Posted at Mon Oct 13, 2008 7:05 am
Hi dburgette,
The voltage should be between 2 to 5 volts.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
