Car Repair Chat - Ask a Question, Get a FREE Answer.
Go Back
1988 BMW 750Li front passenger seat
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Fri Jun 20, 2008 5:37 pm |
By
huskerborn,
Likes cars! |
Give Feedback | Votes: 0 |
Interior problem
1988 BMW 750Li 6 cyl Two Wheel Drive Automatic 90,000 miles
The seat back was reclined (electric). When attempting to bring the seat back up to 90 degrees,
the left side of the seat back raised but the right side (closest to the door) did not. As I continued to play with the recline switch, it finally raised equally on both sides into the upright position. BUT...when I sat in it, the right side moved back as if the motor slipped, now the entire seat back is down and dead. At least the left side is dead. Help. Thanks.
| Find a
car repair manual for your BMW 750Li Repair Question. |
Posted at Fri Jun 20, 2008 5:59 pm |
By
tjegz,
Likes cars! |
haha,1988 BMW 750Li ... i have one~
| Find a
Posted at Sun Jun 22, 2008 8:06 am |
By
Dr. Hagerty,
Moderator |
                    (418) Give Feedback | Votes: 9 |
I understand your question. The distinction between the motors is one is for the seat back and the other is the seat base. The way to tell them apart is to plug the electrics back in(this is why I do not take the seats out of the car) and operate the seat back and observe which of the motors is running, I believe the motor towards the front is the one but my memory isn't what it used to be. As to the cable question, the inside cables need to come out completely because you are going to shorten the black plastic that houses the cables by about 1/4" and to do this you are going to warm up the metal ends just enough to get the plastic to start to melt and let the metal ends pull off, do not get them too hot, just enough to start to get the ends loose, do that and then shorten the plastic tubes, heat the metal ends enough to let them push back on to the plastic tubes, once again, not too hot. This may require a little trial and error so lets keep the errors to a minimum, don't use too much heat!
| Find a
Posted at Mon Jun 23, 2008 9:05 am |
By
huskerborn,
Likes cars! |
WOW! That was actually a piece of cake. Next time I won't have to take out the seat. Thanks Doc! Next paycheck, donation for the cat.
Thanks again,
"Husker Born"
by the way, how much money did you just save me?
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
