Posted at Sat Apr 26, 2008 2:34 pm |
By
originalspy,
Have Donated |
Give Feedback | Votes: 0 |
Electrical problem
1988 Acura Legend 6 cyl 242k miles
Hi Guys,
Something is slowly sucking power from my battery while the car is off. If I don't start it for about 3 or 4 days, the battery is so dead that I can't even pop the trunk.
Key Notes:
1. The battery is brand new.
2. No visible lights are on anywhere.
3. My cable terminals are loose and I tighten them by wedging screws between them and the battery terminals.
I have 2 questions...
1. How do I use a voltage meter to find the source of the power drain?
2. Can the inserted terminal screws have anythng to do with the problem?
Thanks,
Paul.
| Find a
repair manual for your Acura Legend Repair Question. |
By
Advertisment,
| Find a
Posted at Sun Apr 27, 2008 7:18 am |
By
originalspy,
Have Donated |
Thanks Ras,
I have one of those 'multi-meter' voltage meters. I set it to 50V and when I test the batt with the car off it reads between 12 & 13, which (I think) is good. But when I disconnect the -ve cable and put the VMeter between the cable and the -ve post it reads nothing. Actually it jumps backward below zero.
I put the VMeter on lower settings (like 10V or 2.5V), but still nothing. I even tried disconnecting the +ve cable (after reconnecting the -ve cable of course) and running the meter between the +ve cable and the +ve post, but still nothing.
What do you think?
Paul.
| Find a
Posted at Tue Apr 29, 2008 5:55 pm |
By
originalspy,
Have Donated |
Thanks Ras,
The VM worked this time. But I pulled out every fuse, even the big ones that were screwed in, and disconnected the alternator and nothing made it drop to zero.
However, when I pulled out the big 70A "Battery" fuse the VM dropped from about 12.5 to about 11, does that mean anything?
If not, what would you recommend I try next?
And I forgot to say earlier that the alternator is about a year old.
Thanks,
Paul.
| Find a
Posted at Wed Apr 30, 2008 10:24 am |
By
originalspy,
Have Donated |
Yeah, I disconnected the only two wires coming into the alternator. There was a small one on the side (near the top) that lead to the battery, and a combo plug at the back which lead to a large electronic cluster. Then I checked the battery voltage again and it was still about 12.5.
Also, just in case there was something up with the neg battery cable I also grounded the +ve pin of the VM on the engine block instead of the -ve terminal while checking voltage and that didn't change the reading.
What about the 70A fuse that made the reading drop from 12.5 to 11, is that significant?
Thanks again,
Paul.
| Find a
Posted at Wed Apr 30, 2008 5:37 pm |
By
originalspy,
Have Donated |
Ok Ras,
I started the car and checked the battery with the neg cable attached and also detached. The VM read 14 with the cable attached and 13 with it detached.
Then with the car still running (just for fun) I hooked the VM between the -ve battery post and the -ve cable (as you described in an earlier post) and the VM read zero. And remember when I do that with the car off, it reads between 12 and 13.
What do you think that means?
Paul.
| Find a
Goto page 1, 2 Next
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
