Logo Automobile Information Add to Favorites  Automobile InformationLogin  Automobile InformationSign Up
Auto Repair
Auto Repair Home
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair How Does it Work
Auto Repair Automobile Safety Inspection
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Car Repair Manuals
Auto Repair Brake Replacement Guides
Auto Repair Tips Car Owners Should Know
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Definitions
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Recent Repair Topics
Auto Repair2001 Bmw X5 Erratic Gea...
Auto Repair1997 Ford Taurus Car En...
Auto Repair2002 Volvo Xc70 Cabin A...
Auto Repair2001 Volkswagen Jetta P...
Auto Repair1998 Chrysler Sebring W...
Auto Repair1996 Nissan Sentra Stal...
Auto Repair2003 Saturn Vue
Auto Repair More Repair Topics...
Free Auto Repair Advice by Certified ASE Technicians
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1987 Toyota Cressida 87 cressida
Posted at Fri Aug 28, 2009 10:46 am
By all stalld out, Have Donated
Give Feedback | Votes: 0
Engine Mechanical problem
1987 Toyota Cressida 6 cyl Two Wheel Drive Automatic 110000 miles
i just bought my daughter a 1987 toyota Cressida.It had been sitting for a year or more when we got it but only has 110,000 miles and looks good.The seller filled up the tank but said their may be some bad gas in it.I put some SeaFoam in the tank and its been starting up but runs rough for a few minutes then clears out.My daughter got the money to register it and started to use it daily.I told her NOT to let the gas get to low or it may cause it to run rough.well she ran it low but then filled it up with fresh fuel.I drove it the other day and it ran like new!!She took it to work the other night and said it stalled but then started it back up.Well now its sitting in a really unsafe area in Orlando and just turns over but not starting?Her friend who is not a mechanic said he asked someone and they told him the fuel pump may have gone bad?Also he said something about the fuel relay?Like I said he is not close to being a Mechanic but just asked someone he knew.I am going to have it towed to our home.She says its a junker but it is really in great shape for 22 yearrs.My main question is what are the things you would check first before buying a expensive fuel pump?She said it stalled a few times and started back up and she just kept driving.But then it stalled and i asked if any noises or warning and she said no.Now it just turns over and won't crank.Like i mentioned it has been sitting due to the owners relative having cancer but i started it up daily.Thanks for your time and Help as I am glad there is a forum to ask these questions too!!!!!I get disability and its the end of the month but if i get a reply will promise to donate!!
Dave in Fla
Find a car repair manual for your Toyota Cressida Repair Question.
Posted at Fri Aug 28, 2009 11:13 am
By rasmataz, Certified 2CarPros Master Technician
Reputation: 14641.8Reputation: 14641.8Reputation: 14641.8Reputation: 14641.8Reputation: 14641.8Reputation: 14641.8Reputation: 14641.8Reputation: 14641.8Reputation: 14641.8Reputation: 14641.8Reputation: 14641.8Reputation: 14641.8Reputation: 14641.8Reputation: 14641.8Reputation: 14641.8Reputation: 14641.8Reputation: 14641.8Reputation: 14641.8Reputation: 14641.8Reputation: 14641.8Reputation: 14641.8Reputation: 14641.8Reputation: 14641.8Reputation: 14641.8Reputation: 14641.8Reputation: 14641.8Reputation: 14641.8Reputation: 14641.8Reputation: 14641.8 (14642) Give Feedback | Votes: 346
Could be the fuel filter that's clogged-up-check that out if it continues do below to determine if its fuel or spark problem.
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
Test Fuses
More Service Repairs...
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Advertise 2Carpros.com
Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l We're Hiring
Copyright © 1999 - 2010 2CarPros.com - Professional Mechanics Online
