Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Tires and Wheels problem
1987 Toyota Corolla 4 cyl Two Wheel Drive Manual
Hi, I have recently put a new tyre on the left passager side of my car front, and I noticed when i had put the tyre on it made a clicking sound similar to that of a broken CV, but it only occurs when I turn left and does not make a sound when I turn right around a bend.... is it my CV?
Generally CV joints fail because the boots (inner/outer) are damaged by road debris (rocks/limbs).
Inspect the boots for leaking lubricant, cuts etc. If you see any it will have to be replaced.
Thanks, I had a look at the wheel etc.... yesterday and after much searching it was apparent that it was the wheel being unbalanced when it was put on the car, just wasnt lined up right when bolted back on, but it has made the knocking less noticable, but as it is rear wheel drive it does not have CV's on the front, didnt know that till yesterday (lol). I think it could be the steering rack perhaps???
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
