Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
The ignition timing is controlled by the ECM and is considered no-adjustable. If the timing hasn't be tampered with, I would say you have another problem elsewhere.
Find a car repair manual for your Pontiac Transport Repair Question.
The car is running hot after driving 65 mph or faster for 5 minutes. Under 65 mph it runs fine. The car has had a new timing chain installed and I was wondering if the chain was one tooth off (misaligned) could that cause overheating at high speed? Or maybe an obstruction in the radiator? The water pump was changed as it started leaking (the water pump was bad). It still over heats. What could be the problem?
Cam timing being off a notch would cause more performance problems than anything else. Did the overheating start after the new timing chain was installed? At this point, I would think your radiator is plugged.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
