Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1991 Ford F150 Overheating
Auto Repair1992 Jaguar Vanden Plas ...
Auto Repair1994 Other Daewoo Models...
Auto Repair2001 Bmw 325
Auto Repair2000 Gmc Safari Safari ...
Auto Repair1998 Chrysler Concorde ...
Auto Repair1999 Toyota Corolla Pro...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1987 Oldsmobile Firenza banging noise, power drops right of
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Goto page 1, 2  Next
Posted at Thu Nov 13, 2008 3:08 pm
By carilchasens, Have Donated
Give Feedback | Votes: 0
Engine Performance problem
1987 Oldsmobile Firenza 4 cyl Front Wheel Drive Automatic
1987 Oldsmobile Firenza, 4-cylinder
Problem developed suddenlyandhas been intermittant.
Revs ok in neutral.
Otherwise, when pushing on the gas, develops loud irregular banging soundlike some kind of preignition or detonation, and power drops right off. Sometimes, one can regain some power by flooring it, other times this doesn't work.
Replacing spark plugs didn't help.
What could be wrong?
This is not a cherished classic car, it is an old beater that we are trying hard to keep running until we can buy something better. We live way up in the bush - not near any repair shop - so having any kind of sophisticated scan is not an option.
Help? Thanks.....
Find a car repair manual for your Oldsmobile Firenza Repair Question.
Posted at Thu Nov 13, 2008 4:18 pm
By James R. Weizel, Moderator
Reputation: 138.3Reputation: 138.3Reputation: 138.3Reputation: 138.3Reputation: 138.3Reputation: 138.3Reputation: 138.3 (138) Give Feedback | Votes: 8
Do you have a "check engine light" and if you do, do you know how to retrieve the ECM codes? The banging noise, is it from the exhaust or out the air intake duct? Please advise.
Posted at Fri Nov 14, 2008 11:53 am
I understand that one can count flashes after connecting terminals A and B in diagnostic connector? I have not, however succeeded in finding a diagnostic connector... where should I look?
The banging occurs just when accelerating, so locating the source is tricky, but it sounds like it is coming from under the hood and not from underneath the car.
Posted at Fri Nov 14, 2008 12:06 pm
The diagnostic connector will be on the very bottom of the dash on the driver's side
Posted at Fri Nov 14, 2008 2:38 pm
I see a connector with 12 cells in 2 rows of six, wires white with black stripe and black with white stripe on top right, tan w. black stripe on other end, orange on bottom right. Should I shove a loop of copper wire in from the back side to connect the white and black wires?
Posted at Fri Nov 14, 2008 3:32 pm
That is the right connector. I nornally use a paper clip stuck in from the front of the connector. I don't remember the wire colors but, I believe it is A & B, the two on the top right. Most of the other terminals will be empty.
Posted at Sat Nov 15, 2008 3:29 pm
Got codes:
flash pause flash, flash... 12
flash,flash pause flash, flash, flash, flash ...would that be 24??
Then it would go back to 12 and repeat.
Note, that service-engine light has been on all the time for years...I HOPE that the code indicates something new.
Any suggestion that would fix the banging/ extreme
power loss even temporarily would be very verywelcome.
Thanks....
Caril
Posted at Sat Nov 15, 2008 6:39 pm
Code 24 is "vehicle speed sensor, VSS". I tells the ECM how fast the vehicle is going. The ECM uses this information to run the cruise control, lock up the torque convertor and other things. You need to more specific about the "banging" noise. I can't hear it so I have absolutely no idea what you are talking about. If you can't describe it any better, have someone else listen to it. I really can't help you unless I get better information. The code 24 may or maynot be part of your problem. Please advise, Jim.
Posted at Wed Nov 19, 2008 7:57 am
Vehicle in park or neutral:
Starts and runs ok, revs ok when given gas, engine sounds normal.
Uphill or accelerating (slow or medium speed, haven't tried fast):
Coughs and loses power badly when given gas; better when you let up on the gas.
Flooring the gas:
OCCASIONALLY catches, stops coughing and takes off.
Code 24, service-engine light has been on constantly for years before this problem appeared.
Posted at Wed Nov 19, 2008 10:58 am
Re-reading your postings, one question pops up. Have you changed the fuel filter? If not, I would change it. It sounds like the engine is starving for fuel.
Goto page 1, 2  Next
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
