Posted at Tue Apr 29, 2008 12:21 pm |
By
alxx72,
Have Donated |
Give Feedback | Votes: 0 |
Brakes problem
1987 Dodge Dakota 6 cyl Two Wheel Drive Manual 187k miles
I bought this truck (87 dodge dakota 2x4 for $300, pretty good condition, considering the year and climate. However, the brake system did not fare as well as the rest of the truck. In particular the HSPV. It is badly rusted and 2 brake lines have snapped off in the valve, so I either get a new one at $289, replace the lines and prorobly the wheel cylnders and calipers( those bleeder screws look bad too)
By this time I'm looking at close to 2x if not more than I paid for the truck.
I came up with the idea of bypassing the HSPV. I would connect the primary line directly to the metering valve on the rear axle, and simply plug the bypass line at the differential/metering valve up front. After which I would adjust the rear brakes so as to try and prevent them from locking up as much as possible. I know this is not recommended, but my question is.....would this work??
| Find a
repair manual for your Dodge Dakota Repair Question. |
By
Advertisment,
| Find a
Posted at Tue Apr 29, 2008 12:40 pm |
By
alxx72,
Have Donated |
The line broke off flush with the valve
| Find a
Posted at Tue Apr 29, 2008 12:42 pm |
By
alxx72,
Have Donated |
basically i wanna know that as long as i plug the bypass line up front i will get pressure to the rears?
| Find a
Posted at Tue Apr 29, 2008 12:58 pm |
By
alxx72,
Have Donated |
I think you are missing a part here. I have a preportiong/metering valve up front, 2 lines, a primary and a bypass line go down and just before the rear wheel there is a "height sensing proportioning valve" the 2 lines go into it, but have rusted away and broke off into it. Then 1 line goes to the metering valve on the rear axle. the valve on the axle (tee) is ok. The height sensing proportioning valve is what i am looking to bypass. I hope that helped
| Find a
Posted at Fri May 02, 2008 7:04 am |
By
dustyr26,
Likes cars! |
I just had the same thing kind of happen to my HSPV. Mine, all the lines are good, I just replaced them last fall. Now I noticed another leak on the back side of the HSPV. It's not leaking from the bleeders nor where the lines are coming in. Looks like there is a hole on the back side. Someone told me that the hole might be there for when the valve goes bad it will leak out of the hole?????? I too looked into replacing the HSPV. Same prices too!!!! I believe I am going to bypass the HSPV and run direct to the splitter on the rear axle. My question is which one is the back line and which is the return line. The front spllit has one line directly straight back to the HSPV and one comes out of the bottom of the Front Proportioning valve and goes to the back HSPV. Anyone know which line to leave and which line to Plug???? I'm thinking the bottom one is the return line.
Thanks in advance, Dustyr26!!!
| Find a
Posted at Fri May 02, 2008 12:18 pm |
By
dustyr26,
Likes cars! |
Thanks,
The combination valve has the two lines coming back to the HSPV. I guess I'm just confused on which of the two to plug at the combination valve. I am assuming it should be the one coming straight back off the end of the combination valve. The other line which I would plug would be the one on the bottom. I will look a little closer once I get under the truck and try to get at it.
I probably will detach both lines back at the HSPV and then press on the brake to see which line shoots the brake fluid out, then that will be the one to connect to the line heading to the tee that goes to each rear tire. I would assume the other would then be the return line and plug that at the front at the combination valve.
Thanks again for the help. It's reassuring to pretend like I know what the heck I'm doing!
Thanks
Dustyr26
| Find a
Goto page 1, 2, 3 Next
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
