Thanks for your response. It certainly seems like the speedo driver chip from here, I recommend removing the instrument cluster and inspecting the unit after disassembly. It is likely that the driver in the speedo has failed, I also request inspection of the service interval board(the one with the batteries attached) As stated earlier, replacement of the cluster might be an easier way to address this issue, if so, a salvage yard might be a suggestion that would help. Call Autobahn dismantling @ (619)444-2290 and speak to either John or Sean. Tell them I sent you.
