Car Repair Forum - Ask a Question, Get a FREE Answer.
Go Back
1987 Acura Integra Cooling fan relay
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Sat Sep 13, 2008 8:45 pm |
By
cmango,
Likes cars! |
Give Feedback | Votes: 0 |
Electrical problem
1987 Acura Integra 4 cyl Two Wheel Drive Manual 221300 miles
My engine has been overheating, and it is apparently because the cooling fan is not coming on. My mechanic has tested the fan motor and the sensor switch, and both appear to be OK. He indicated it might be a faulty relay. My shop manual (from Acura) shows a cooling fan relay switch in the engine compartment, front right. I have removed the headlight, air filter housing, radiator reservoir, and everything in the vicinity that might have been concealing it, but unless it's behind the cowling inside the wheel well, I cannot find a relay anywhere between the fan motor and the ignition coil.
Any help?
| Find a
car repair manual for your Acura Integra Repair Question. |
Posted at Sun Sep 14, 2008 7:43 am |
By
cmango,
Likes cars! |
Thanks KHLow2008,
But that is the same diagram I have in my Acura manual...and there is nothing there, where the cooling fan relay is shown to be. I do not have A/C, so there is no A/C compressor clutch relay, A/C diode, or condensor relay, either.
| Find a
Posted at Sun Sep 14, 2008 10:09 am |
By
cmango,
Likes cars! |
It's not. Nothing there. I've removed the air filter housing, the radiator reservoir, the headlight. There is no relay there. I've traced the wire from the fan motor, and right behind the headlight it joins the wiring harness. Any other ideas? Ever heard of it being mounted anywhere else? Ever heard of there NOT being any cooling fan relay at all?
| Find a
Posted at Wed Sep 17, 2008 1:43 pm |
By
cmango,
Likes cars! |
Sorry for the delay. I'm the original owner, and as far as I now it's never been removed for any reason. I've looked on the left side, too, but there's so much stuff over there I can't see, unless I get it on a lift. Think I'll have to go ask the dealer. My suspicion is that it has been combined with other relays into some sort of master box somewhere that I can't find or identify from my manual.
Will post any answer I get.
Thanks anyway.
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
