Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Manual Ask a Car Repair Question
Auto Repair Manual Car Questions by Manufacturer
Auto Repair Talk Auto Questions by Topic
Vehicle Repair Car Repair Forum
Auto Repair Talk Car Repair Troubleshooting
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Video Series
Vehicle Repair How to Use Test Equipment
Auto Repair Manual Car Maintenance Information
Vehicle Repair Service Engine Soon Light
Vehicle Repair Car Parts and Equipment Store
Vehicle Repair How Does it Work?
Vehicle Repair Safety Inspection
Auto Repair Manual Online Car Repair Manual
Vehicle Repair Smog Test Preparation
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1995 Ford Windstar Door...
Auto Repair2001 Chrysler Town And C...
Auto Repair2005 Other Nissan Models...
Auto Repair1984 Other Toyota Models...
Auto Repair1998 Other Ford Models R...
Auto Repair1997 Chevy S-10 Full Ga...
Auto Repair1999 Other Hyundai Model...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1986 Nissan Truck transmission problem
Welcome to our question and answer forum where over 6,000 free auto repair questions are answered every month, after you have completed our free signup you will able to ask a question and receive an answer from one of our many forum members.
If you elect to donate any small amount of money we will assign one of our 2CarPros Certified Repair Technicians to answer your question. Questions with donations are answered promptly and 100% of the donation is awarded to the technician helping you.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Tue Jun 17, 2008 12:50 pm
By Nissan720, Likes cars!
Give Feedback | Votes: 0
Transmission problem
1986 Nissan Truck 4 cyl Four Wheel Drive Manual 270000 miles
I have a 1986 Nissan 720 pickup 4x4 MT with a z24 motor. lately my truck doesn't like to move, it will roll all day while its in neutral with no problems or binding of any kind. When I put it in gear (engine running or not) and have the clutch disengaged (pedal to the floor) it will only roll maby 2-3 in. then stop and it wont shift out of gear unless i power through it. I have checked the oil in the transmission and changed the transfer case thinking that was the problem. I know the syncros are going bad cause i have to clutch it just right and bring up the revs to down shift (up shifting is ok but sometimes have to do the same thing). My question is, is there something i can replace inside the transmission (if it is the culprit of the problem) or will i just have to bite the bullet and replace the whole thing?
Find diagnostic tools, replacement parts or locate a car repair manual for your Nissan Truck Repair Question.
By Advertisment,
Posted at Tue Jun 17, 2008 1:19 pm
By Docfixit, Tech level 6
Reputation: 75.6Reputation: 75.6Reputation: 75.6Reputation: 75.6 (76) Give Feedback | Votes: 3
A clutch engagement problem sounds like what you are experienceing.
Has the clutch master and slave been verified as functioning properly?
Check their operation. if this is good then another possibility is possible the pilot bearing binding on the input shaft so even though the clutch works the input shaft still turns making it very hard to shift .
And sounds like damage to syncros has occured.
Let me what you find
Posted at Wed Jun 18, 2008 1:06 am
I believe they are both good. I troubleshot a little more earlier by putting the transfer case in neutral and shifted through all gears with engine running to see if I could find any binding in ant certain gear. When i depressed the clutch the main drive shaft stopped spinning and when i released it it spun with no binding in any gear. That leads me to believe that the clutch system is working properly.
Posted at Wed Jun 18, 2008 6:19 am
With that info I would say internal problem for sure possible cause input shaft must be unable to free spin when clutch is engaged this will keep lay shaft turning. Making shifting hard also it would not roll because with clutch in the the input still turns the lay so with the driveshaft keeping the main shaft turning via rolling of the wheels it can't because the lay shaft is in a bind with the input keeping main from free wheeling.
Hope this makes sence
You will never know till you tear it down
Posted at Wed Jun 18, 2008 8:45 am
By KHLow2008, Moderator
Reputation: 259.1Reputation: 259.1Reputation: 259.1Reputation: 259.1Reputation: 259.1Reputation: 259.1Reputation: 259.1Reputation: 259.1Reputation: 259.1Reputation: 259.1Reputation: 259.1Reputation: 259.1Reputation: 259.1 (259) Give Feedback | Votes: 12
Hi Nissan720,
With engine off, engage each gear including reverse and test if any gear it will free up with clutch pedal depressed.
Posted at Wed Jun 18, 2008 11:54 am
KHLow2008,
With engine off (or on in this matter) as long as i haven't moved to that binding point I can shift freely into any gear, it is only after i have reached that binding point that i have problems shifting. Another tidbit of info is that when I do try to drive it (back into the parking spot only) the truck shakes while moving.
Posted at Thu Jun 19, 2008 5:01 am
Hi Nissan720,
What I meant was engage 1first, roll till it binds.
Free it Engage 2nd gear, roll it till it binds. Repeat for all other gears and see if any gear will not bind.
Once the binding point is reached, does rolling the truck in reverse direction. free up the gears?
When the vehicle shakes when reversing, it could mean one of the forward gears is engaged and not freeing up.
You would have to strip the trans to find out the problem. Most probably excessive clearance due to a loose lock nut since you suspect some synchros are bad.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
