Auto Repair Chat - Ask a Question, Get a Free Answer
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1986 Chevy Silverado vacume digram
Posted at Tue Nov 03, 2009 1:45 pm |
By
nunoit,
Likes to hang around! |
Give Feedback | Votes: 0 |
Engine Performance problem
1986 Chevy Silverado V8 Four Wheel Drive Automatic
i have a 1986 suburban silverado there is no vacume digram under the hood. i want to hook the way it is supposed to go(cali or fed). 350 moter some vacum is connedted not all of it. from what i have found there is no ecm no cat(never was), 4 barrel carb egr ok engin is jasper air cleaner only has 1 hose connection for hot air moter. all vacum digrams welcome also proper air pump digram needed. thanks in advance joe |
Find a
car repair manual for your Chevy Silverado Repair Question.
Posted at Tue Nov 03, 2009 1:52 pm |
By
bluelightnin6,
Certified 2CarPros Technician |
                                 (3408) Give Feedback | Votes: 141 |
what size engine? 5.0L, 5.7L etc.. gasoline or diesel? |
Find a
Posted at Tue Nov 03, 2009 1:57 pm |
By
jdl123,
Have Donated |
                        (2519) Give Feedback | Votes: 61 |
Don't know if the above will work for you or not? Welcome to the forum. |
Find a
Posted at Wed Nov 04, 2009 6:23 am |
By
nunoit,
just a fue ? what is efe valve (heat riser), dtstr tvs (?) and is hose that connects to air cleaner (between vapor can and decel vav) just a bleed for vapor canianster, other than that i think i can make work. there is some weard valve that connects to vapor canister wonder what it is, has 4 ports 2 for vapor 2 for vac ill see if i can pix to post. also carb has bowl vent where does it connect. (pluged now) once again thanks joe |
Find a
Posted at Wed Nov 04, 2009 8:12 am |
By
jdl123,
Have Donated |
I believe tvs is thermal vacuum switch and efe is early fuel evaporation. |
Find a
Posted at Fri Nov 13, 2009 6:18 pm |
By
nunoit,
| bluelightnin6 wrote: | | what size engine? 5.0L, 5.7L etc.. gasoline or diesel? |
5.7 gas |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
