Car Repair Advice by Professional Automotive Experts
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1985 Oldsmobile 98 Rough idle even in drive range-no back
Posted at Tue Nov 17, 2009 8:01 pm |
By
Cfoxz,
Have Donated |
Give Feedback | Votes: 0 |
1985 Oldsmobile 98 6 cyl Front Wheel Drive Automatic 80 miles
Replaced motor, Has about 80 miles on it. all components except throttle body fuel pump and fuel rail harness. No codes on check engine except normal 1-2. Once accelerated it runs good, lots of power.My shop mechanic can't figure out the problem and he is a very good mechanic. I have all the shop manuals for it.Could a dirty sock on the fuel pump or pulsator be causing the problem? Also replaced some of the firewall relays . Also where can I get a Dorman replacement fuel injection wire harness? Your list does not go down to 1985 Thanks, Chaz |
Find a
car repair manual for your Oldsmobile 98 Repair Question.
Posted at Fri Nov 20, 2009 1:11 pm |
By
Docfixit,
Certified 2CarPros Master Technician |
         (4955) Give Feedback | Votes: 81 |
Hi
So I understand the problem idle is rough as in miss or low? does it smooth out with bringing RPMs up?
Unplug MAF see if idle smooths out. Has TPS and ISC been ruled good?
Let me know
Thanks for donate |
Find a
Posted at Fri Nov 20, 2009 6:57 pm |
By
Cfoxz,
Have Donated |
Map sensor is new. Iac motor is new. Tps is working ok. New Distributor, and cap. Car does run smooth except when it is not moving- in drive, reverse or park. Has full power on acceleration. No check engine light. Codes check out with 1-2 all ok! New fuel filter, new fuel injectors, new spark plugs- not Bosh platinium. Egr ststem has completely replaced. and new plug wires. Starts up with a fast idle and comes down to normal in a few seconds and then idles rough . Weird! Thanks, Chaz |
Find a
Posted at Sat Nov 21, 2009 2:49 pm |
By
Cfoxz,
Have Donated |
My mechanic solved the problem! The New Distributor Cap from Autp Zone was defective and firing on 4 strong cylinders and 2 very weak ones and the connector tips were all sloppy loose. Second time got bad part from them. Will not use any Bosch iparts either. But have a question: My 2 front motor mounts need replacing. Can you tell me which mounts I will need to replace and are there Hydraulic mounts on the tran mounts . should I get all the mounts replaced- motor and trans? My shop manual is not too clear on them. Thanks Chaz |
Find a
Posted at Mon Nov 23, 2009 7:34 am |
By
Docfixit,
Great news yes Auto Zone not best on parts use NAPA myself. As for mounts early design solid rubber later design hydraulic. Can use either hydo or gas smooth out vibs better. As for trans if 440-T4 hydraulic 4T60-4T60TE solid mount.
New engine new mounts would be the way to go. |
Find a
Posted at Mon Nov 23, 2009 4:16 pm |
By
Cfoxz,
Have Donated |
Thanks, Chaz |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
