Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2006 Toyota Corolla
Auto Repair2004 Ford Explorer Tie Rod
Auto Repair2007 Dodge Charger Tach...
Auto Repair2003 Bmw 325 Blower Stops
Auto Repair1998 Chevy Cavalier Tra...
Auto Repair1996 Honda Accord No Po...
Auto Repair1989 Subaru Outback Car...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1984 Chevy Blazer S10 Blazer
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Wed Aug 27, 2008 9:31 am
By kvinnie3, Likes cars!
Give Feedback | Votes: 0
Electrical problem
1984 Chevy Blazer 6 cyl Four Wheel Drive Automatic 100000 miles
I have a 1984 s10 blazer V6 4x4 starts intermittently... sometimes will start and run fine, others (sometimes weeks in between) nothing...Getting fuel to cylinders.. getting 12v to the module on the side of the engine and out of that (plug wire to distributor has spark) but no spark to plugs...also a couple other notes.. .the oil gauge is going crazy bouncing up and down rapidly with the key in the "on" position and also the choke light is now on... Any and all help is appreciated...
Find a car repair manual for your Chevy Blazer Repair Question.
Posted at Wed Aug 27, 2008 1:28 pm
By rasmataz, Certified 2CarPros Master Technician
Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4Reputation: 987.4 (987) Give Feedback | Votes: 75
(plug wire to distributor has spark) but no spark to plugs... Lets start with this-inspect the distributor cap and rotor-the secondary power surge has to go thru the cap and rotor to fire the plugs-also test the coil wire
Posted at Wed Aug 27, 2008 1:45 pm
How would I go about testing that? take the cap off and use a circuit Light?? Can do... I'll check it tonight....
Posted at Wed Aug 27, 2008 1:53 pm
Fabricate a plug wire -Ground the coil tower on top of the rotor button and crank engine over -do you have spark?
Posted at Thu Aug 28, 2008 5:26 pm
Ok... Pulled the cap off the distributor, and the rotor ( think).. Unplugged ECM and checked it out.. looks kinda beat up has white sticky Lithium on the bottom... But plugged in the Positive lead to the ECM (where I had 12 V) and tested the terminals on the other side of the ECM and I had a dimly lit test light.. so I don't think its letting a full 12 v pass through it...
Posted at Thu Aug 28, 2008 5:29 pm
How's the coil and did you check the pick-up coil resistances and short to ground?
Posted at Fri Aug 29, 2008 5:33 am
Ok.. You lost me on that one.. .I put a new ignition coil on it and I thought it would solve the problem about 2 months ago... but it is both sending and receiving power...
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
