Car Repair Help by Professional Mechanics
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1983 Buick Lesabre wont start
Posted at Tue Feb 09, 2010 8:58 am |
By
lemonlover78,
New to the forum |
Give Feedback | Votes: 0 |
Electrical problem
1983 Buick Lesabre V8 Two Wheel Drive Automatic
my battery is reading around 12v. i had my altenator tested at autozone. they told me it was good? when i try to start the car, i hear the starter engage and if i hold it in start the starter tires down. no crank. could this be an ignition switch. a few days ago the isturment cluster was blowing fuses then popped now wont come on. the battery lights been on also. could all these problems be realated? |
Find a
car repair manual for your Buick Lesabre Repair Question.
Posted at Tue Feb 09, 2010 9:46 am |
By
jdl123,
Moderator |
     (3064) Give Feedback | Votes: 92 |
welcome to the forum. I'd have to make sure he battery has a full charge and the connections are good. With everything turned off, use digital voltmeter across posts. The generic spec for a full charge is 12.6 volts. Take a second reading across battery posts, engine running, if you can get it started, the second reading should be higher than the first, if the charging system is working. The charging system needs to be checked on the vehicle. The alternator my test fine at the store,but, if there is a problem with wiring circuits to or from the alternator, it won't charge on the vehicle. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
