Car Repair Forum - Ask a Question, Get a FREE Answer.
Go Back
1982 GMC Sierra Truck will not start
Welcome to our question and answer forum where over 6,000
free auto repair questions are answered every month,
after you have completed our free signup you will able
to ask a question and receive an answer from one of our
many forum members.
If you elect to donate any small amount of money we will
assign one of our 2CarPros Certified Repair
Technicians to answer your question. Questions
with donations are answered promptly and 100% of the
donation is awarded to the technician helping you.
Watch our new
Car Repair Video Series
with Ken Lavacot.
Posted at Thu Feb 28, 2008 9:52 pm |
By
vega99683,
Have Donated |
Give Feedback | Votes: 0 |
Engine Mechanical problem
1982 GMC Sierra V8 Four Wheel Drive Automatic 150000 miles
I have a 1982 GMC Sierra pickup with a 305 5.0L V8 with automatic transmission. I've been having a fuel problem and have ran out of options.
The truck has dual tanks and i've recently replaced the battery, fuel pump, tuneup, plugs, cap and rotor, plug wires, fuel filter.
My most recent problem is after i replaced the fuel pump the truck started. I drove 5 miles and returned home with no problem. The truck sat for 2 hours and now its not getting fuel again. No fuel is getting into the carburetor. I haven't taken off the fuel line but assume that it certainly isn't getting fuel. Is there something else that might be affecting the fuel from getting into the carburetor? What things can i look at? This truck has been leaving me stranded lately. I would drive a few blocks and then it would just stall as if it was out of fuel. After replacing the fuel pump i made it about 5 miles but now it is not getting fuel again. Please help.
| Find
diagnostic tools,
replacement parts
or locate a
car repair manual for your GMC Sierra Repair Question. |
Posted at Fri Feb 29, 2008 9:05 am |
By
vega99683,
Have Donated |
I will check the fuel filter tonight but i'm fairly certain that it is in correctly. I had just driven 5 miles without problem but then went out to start it again...no fuel to carburetor. The fuel pump is a mechanical, carburetor is a rochester 4 barrell (stock) with 305 motor. It just really upsets me that i've been having this problem with lack of fuel. Thank you for the feedback, much appreciated. If you think of anything else, please let me know.
quote="pear69"]Make sure the fuel filter is installed correctly. Some fuel filters have directional flow, yours may be in backwards.
Is the fuel pump a mechanical fuel pump or an electric pump?
Is the carb 4 barrel or two barrel? What type of carb is it? Rochester--Edlebrock--Holley--ETC.
Make sure it is not getting fuel.[/quote]
| Find
diagnostic tools,
replacement parts
or locate a
Posted at Sun Apr 20, 2008 5:53 pm |
By
mrock08,
New to the forum |
Hey I recently purchased a 82 sierra and loving it. Only problem was is that I was dealing with the same situation you were. I came to the conclusion that the cause of the problem was the fuel tank switch modual that is located on the frame. Even though I could hear it switch when I pressed the button in the cab, it wasn't fully engaging. I decided to remove the one tank and the fuel modual all together. I connected the line from the fuel assembly to the fuel rail with rubber fuel hose. After a few cranks it fired right up and ran terrific. I hope this helps...
mRock08
| Find
diagnostic tools,
replacement parts
or locate a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
