Auto Repair Forum - Ask a Question, Get a Free Answer
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1981 Mercedes Benz 200e Engine problem
Posted at Sat Jul 04, 2009 12:09 pm |
By
contactin,
Have Donated |
Give Feedback | Votes: 0 |
Engine Mechanical problem
1981 Mercedes Benz 200e 4 cyl Two Wheel Drive Manual 150000 miles
Gray market car with carburetor. Engine idles OK, spark is fine as is vacuum. Compression on all four cylinder is 170. However, when revved, there is a lot of rattling noises as if the timing is not correct and the engine has not power. Tried to adjust the timing, but even with the distributor turned fully clockwise, the advance is not enough. Took the valve cover off to check the timing belt, and found a large piece of plastic broken off that looks like a part of a timing belt guide. Timing belt seems tight. Valves have the right clearance. Thought that maybe the broken guide had caused the timing belt to skip. However, everything seems to line up when the crankshaft is set at TDC, the mark on the cam shaft lined up with crankcase, and the distributor rotor points to the notch for cylinder 1. I am not sure what to check next to find out what is wrong. |
Find a
car repair manual for your Mercedes Benz 200e Repair Question.
Posted at Sun Jul 05, 2009 2:06 pm |
By
merlin2021,
Certified 2CarPros Master Technician |
                            (2867) Give Feedback | Votes: 97 |
Check for misrouted plug wires, if a tune-up was done, a wire or two may have been crossed. I have no info on this timing chain/belt, too old! But if compression is OK and marks line up, then I doubt the belt slipped. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
