Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Discount Auto Parts
Vehicle Repair Car Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair2001 Dodge Dakota Automa...
Auto Repair2002 Daewoo Leganza Starter
Auto Repair2007 Alfa Romeo Spider
Auto Repair2003 Volkswagen Jetta Br...
Auto Repair1995 Isuzu Trooper Slow ...
Auto Repair1969 Chevy Corvette Brakes
Auto Repair2001 Oldsmobile Bravada ...
Auto Repair2005 Toyota Corolla Sque...
Auto Repair1999 Honda Prelude Shift...
Auto Repair2003 Ford Explorer Anti ...
Auto Repair1989 Chevy Celebrity Rece...
Auto Repair2001 Dodge Ram Sensor Lo...
Auto Repair2004 Chevy Cavalier 2004...
Auto Repair1990 Ford Aerostar Runs ...
Auto Repair2004 Chevy Silverado Spe...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1980 Other GMC Models Start but No Run
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Tue Apr 22, 2008 4:36 pm
By DK1, New to the forum
Give Feedback | Votes: 0
Electrical problem
1980 Other GMC Models V8 Four Wheel Drive Automatic
I have a 1980 GMC K2500 that has all of a sudden developed some strange problems. I started it up and the alt gauge buired the needle past 18 volts. I then shut it off and now the truck will start and fire but not run. I assumed there was an electrical short and began to diagnose the problem. Upon trouble shooting I disconnected the starter wires and the alt wires from any contact with the rest of the positive system or ground. I began running tests with my DMM meter and found that in the run position, on the ignition switch. With the meter connected to the junction block and to ground there is a direct connection to ground. Is this correct in the wiring. If not, and I assume not. Is it possible that the ignition switch is the problem? I have checked all of the wiring under the hood to the fuse box and all is ok. How would I go about testing the ignition switch?
Thank you
Find a repair manual for your Other GMC Models.
By Advertisment,
Posted at Fri Apr 25, 2008 10:24 pm
By rasmataz, Certified 2CarPros Master Technician
Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7Reputation: 742.7 (743) Give Feedback | Votes: 66
I have a 1980 GMC K2500 that has all of a sudden developed some strange problems. I started it up and the alt gauge buired the needle past 18 volts. I then shut it off and now the truck will start and fire but not run. I don't get it please be specific is to the problem especially this one I then shut it off and now the truck will start and fire but not run are you talking about it won't move an inch?????????
Alternator gauge going whack- could be a problem with the internal voltage regulator.
Posted at Tue Apr 29, 2008 4:37 pm
As indicated in my previous posting the starter wires and the alt wires are not connected i.e. phisically disconnected for the purpose of this test.There is a contuninuty directly to ground thru the junctuion block. I this correct for the wiring? I have inspected all of the wiring under the hood to the fuse box connector and all is good. As far as start but no run goes the engine fires at the start position but as soon as I let the key go to effectively let the engine run. It the engine shuts off.
Posted at Tue Apr 29, 2008 4:41 pm
Its pointing towards a bad ignition switch test it out-when you let go the key from start the ignition circuit should power the ignition system but its not that's why it dies out. No power to coil
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
