Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair Car Repair Manuals
Auto Repair How Does it Work
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Automobile Safety Inspection
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Table
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1998 Volkswagen Jetta F...
Auto Repair2001 Kia Sephia Car Won...
Auto Repair1989 Gmc C1500 Pcv
Auto Repair2002 Lincoln Town Car R...
Auto Repair2004 Buick Park Avenue ...
Auto Repair1980 Chevy Camaro Th350...
Auto Repair1991 Toyota Camry No Fi...
Auto Repair More Repair Topics...
Auto Repair Talk - Ask a Question, Get a Free Answer
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1970 Pontiac GTO break in oil and fluids
Posted at Sat Nov 07, 2009 6:41 pm
By gtojbc, Have Donated
(7) Give Feedback | Votes: 0
Engine Mechanical problem
1970 Pontiac GTO V8 Two Wheel Drive Automatic 0
I am completing a a complete overhaul of engine. with new standard crank, cam, pistons, rings, bearings, oil pump, lifters.
This rebuild will not be used for racing purposes, only for show and sunday drives.
Although engine has over 180,000 miles, it has all original drivetrain; I have owned the car since new and religiously changed the oil and filter over the life of the engine at 5000 mi or less intervals. The cylinders had minimal wear and are still within 1/1000th of factory tolerance.
Consdiering the change in motor oil specs over the last 40 years, I suspect that use of the current shelf grade penzoil multiweight resulted in a main bearing seizing.
I want to properly lubricate this engine for break in and it's future occasional use. What brand/specs of lubricants and servicing processes do you recommend?
Find a car repair manual for your Pontiac GTO Repair Question.
Posted at Sat Nov 07, 2009 7:12 pm
By pear69, Moderator
Reputation: 489.5Reputation: 489.5Reputation: 489.5Reputation: 489.5Reputation: 489.5 (490) Give Feedback | Votes: 6
First, being that you say the cylinders were within .001 of factory tolerance -- What machine work was done to the cylinder walls -- re-honeing or re-boreing? Did you change the piston rings? If so, what material are the rings? In order to seat the rings properly, I must know exactly what was done to the cylinder walls..
Posted at Sat Nov 07, 2009 7:32 pm
The cylinders were honed, note bored. All replacement parts are factory standard; crankshaft, cam shaft, bearings, lifters, valve guides, pistons, rings, oil pump (increased to high volume). Valves were undamaged, however the valves and seats have been ground and are still within tolerance. block and heads have been cleaned.
Posted at Sat Nov 07, 2009 8:51 pm
The important thing as it relates to engine break in, and oil, is the cylinder walls and the piston rings. These are the parts that really MUST be properly addressed -- everything else is important (don't get me wrong)..First realize this, the cylinder walls and the piston rings are NOT perfectly mated (yet). They have microscopic ridges or bumps on them that must be "worn" off..This is what is called break in. The break in, perfectly matches the cylinder walls to the piston rings so you can have the best compression possible - and this period will be VERY important (to you especially) because is seems that you will not be putting many miles on this engine...
An important step, BEFORE you fire the engine for the first time, is to pre-lube the engine. This is done by inserting a tool, connected to a drill, into the distributer hole. I have a Comp Cam pre lube tool (part number 4921) they are about 25 or 30 bucks. This will ensure that you have oil distributed properly BEFORE the initial start...OK - now to answer the question --LOL -- I suggest using straight 30 weight NON DETERGENT (if you can find it) and NON SYNTHETIC oil for the first to 800 to 1000 miles. The breaking process MUST be done as follows: Do not go over 60 MPH for the first 1000 miles. In these 1000 miles, vary your speed and drive up and down hills (if possible) often. Do not drive at steady consistant speeds. Do not "lug" the engine by driving in high gear. The reason for this is to vary the loads "gentaly" on the piston rings. If you load them too hard or too soft you will not get a good seal and it will result in smoking and/or excess oil consumption.
Also, drive these 1000 miles as soon as possible. Not all at once, but do not just drive on Sunday and every once in a while. It is important not to let oil drain off of the cylinder walls and condensation to accumulate in the crank case, which is what happens when you let any engine sit for a long period...
After the 800 to 1000 mile break in period, you should use 10w30. Also, if you want, you can use synthetic oil at this time. I do suggest switching to synthetic for reasons I will discuss, if you want. I further suggest using either Mobile 1 (not just Mobile) or Castrol oil brands -- for reasons I will also discuss if you want.
BTW - Im sure you replace the oil filter every time you replace the oil, but if it is possible and not too messy, try to replace the filter only after the first 200 miles. This is not really necessary, but I do it and I have found (when inspecting oil filters) excessive debris in it from the rebuilding process. If you do - do this -- be quick about it, it is a little messy, and be sure to add a little oil afterwards...
Posted at Sat Nov 07, 2009 9:10 pm
One more thing, change the oil more frequently, being that you are putting low miles on this engine...Every internally combustion engine accumulates condensation (water) inside of the engine. It is a result of the heating and cooling of the engine and there is no way to avoid it. This gets into the oil. This water usually does not cause a problem because it is evaporated effectively during the next engine heat cycle, which in most cases is,the next day. It seems that you will not be consistantly running the engine every day (after the break in period) so change the oil more frequently -- maybe every 2000 miles or at least twice a year (before storage and before long storage periods in the winter is best)
Factory suggested oil service periods of 3000 or 5000 are assuming that the car is being driven frequently..
Posted at Sat Nov 07, 2009 9:13 pm
Thanks. That is very helpful. Two additional issues.
1) Is it helpful to use special lubricant aditives during the first 1000 miles for properly mating cam and lifter surfaces. If so what product do you recommend?
2) Materials in my research indicated that current multigrade petroleum oils in use do not have sufficient zinc to keep internal mating surfaces smooth over time in these older engines. Is that a problem I need to address with an additive, or special specification engine oil? If so, which product(s) do you recommend?
Posted at Sat Nov 07, 2009 9:23 pm
thanks. Usually, the car is driven at least 25 miles at a time, round trip, at least once per week. but thanks for that reminder about oil change intervals.
As to break in procedures:
It will be challenging to break it in. I usually drive a late model cadillac for extensive driving.Smile
Posted at Tue Nov 17, 2009 8:27 am
Sorry about that--
There is no additive that should be put in the oil at break in. However, when installing the cam, it must be coated with cam shaft assembly lube during installation.
As far as the zinc content of oil goes, your research has a little merrit. The most important thing about oil is its' ability to carry dirt and debris away from the bearing oil "wedge". This wedge is measured in thousandths of an inch - (bearing clearences). If this wedge is interrupted for any amount of time - while the combustion is taking place - and the pistons are pounding down on the crankshaft -- the engine will eventually fail..I suggest switching to fully synthetic Castrol Syntec 10-30 or Moble 1 10-30. These two oils -IMO- have the proper chemical compounds/detergents/and debris suspension properties that are the best for any engine..
Posted at Tue Nov 17, 2009 8:43 am
thanks. will do.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Home l Help l Privacy Policy l User Agreement l About Us l Computer Repair Question l Contact Us l Link to Us l We're Hiring l Affiliate Program
  Copyright © 1999 - 2009 2CarPros.com - Professional Mechanics Online
