Logo Automobile Information Add to Favorites  Automobile InformationLogin  Automobile InformationSign Up
Auto Repair
Auto Repair Home
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair How Does it Work
Auto Repair Automobile Safety Inspection
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Car Repair Manuals
Auto Repair Brake Replacement Guides
Auto Repair Tips Car Owners Should Know
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Definitions
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Recent Repair Topics
Auto Repair2002 Mazda Protege Low ...
Auto Repair2002 Mazda Protege Almo...
Auto Repair2002 Dodge Neon Ps Belt...
Auto Repair1996 Dodge Caravan Car ...
Auto Repair1997 Ford Escort
Auto Repair1995 Ford Escort Hi
Auto Repair1994 Ford Escort Computer
Auto Repair More Repair Topics...
Auto Repair Help by Professional Mechanics
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1970 Ford Ranchero Car won't start, gas coming out of carb,
Posted at Thu Jun 18, 2009 9:41 am
By fredcespedes, Have Donated
Give Feedback | Votes: 0
Engine Performance problem
1970 Ford Ranchero V8 Two Wheel Drive Automatic 50,000 miles
Hello - I have a 70 Ranchero (351C 4V), with a Holley 750 Carb (with manual choke), I ran out of gas the other day, and in the process flooded the engine trying to get it started after I filled it with gas. I had no starting fluid so poured a bit of gas into the carb, first time I have done this. After the car sitting for more than 24hrs, I attempted it to start again, only to have the engine (carb area) catch on fire. I was able to put it out, but the reason was because gas was pouring out of carb. Did I ruin it by puring gas in there. I am scared to try it again, but I know it's becuase the engine is flooded, this has happended many times before and I always get it started. But because gas was pouring out of the carb this time I am scared to try again If I do want to try it again on my own, how long should I wait before I try to start it. I have a on/off option with my fuel pump, will that do anything?
On top of this, at one point I pulled key out of ignition, but the power stayed on in the car, this is the first time this has happened. Battery died as well, but I was able to jump it so that it can get some juice. Then I read something about when an engine is flooded, it will not let the starter function correctly. Please help! I don't want to have to spend an arm and leg to get this fixed. Any suggestions?
Thanks for your time and help!
Freddy
Find a car repair manual for your Ford Ranchero Repair Question.
Posted at Fri Jun 19, 2009 4:33 am
By 2CarPros Jack, Certified ASE Technician
Reputation: 11816.9Reputation: 11816.9Reputation: 11816.9Reputation: 11816.9Reputation: 11816.9Reputation: 11816.9Reputation: 11816.9Reputation: 11816.9Reputation: 11816.9Reputation: 11816.9Reputation: 11816.9Reputation: 11816.9Reputation: 11816.9Reputation: 11816.9Reputation: 11816.9Reputation: 11816.9Reputation: 11816.9Reputation: 11816.9Reputation: 11816.9Reputation: 11816.9Reputation: 11816.9Reputation: 11816.9Reputation: 11816.9Reputation: 11816.9 (11817) Give Feedback | Votes: 111
One at a time.Lets stop the fuel flow before worrying about the battery.Holleys are famous for sticking the needle and seats, that is why fuel is pouring out of it.Is it the front float bowl or the rear or both?.Either way, fuel pump off, loosen the straight blade screw on top of the float bowl about 1/4 turn.Then unscrew the nut under it (counterclockwise) while counting the number of turn.This is the needle and seat.Once out you will most likely see something hanging it up, clean it and reinstall.After the car starts, remove the small plug about 1/2 way up the side of the float bowl, this is to check float level. Gas should be just below bottom of hole, if you bump the car, fuel should just come out, same goes for front and rear.You may need new gaskets for the screw and adjusting nut. Or you can try tapping on top of the screw with a plastic screwdriver handle it will probably free it up, I just prefer to clean them out
Posted at Fri Jun 19, 2009 8:28 am
Thanks for the response. I will try these out and see what comes of it. ALthough I'll be on vacation for next few weeks so may have to wait. Talk to you all in a few weeks. Thanks for your time!
Posted at Fri Jun 19, 2009 9:19 am
No problem......... Have a good vacation
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
Test Fuses
More Service Repairs...
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Advertise 2Carpros.com
Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l We're Hiring
Copyright © 1999 - 2010 2CarPros.com - Professional Mechanics Online
