Engine Mechanical problem
1969 Other Ford Models V8 Two Wheel Drive Manual 120,00 miles
i have a 1969 ford f100 trk with a 360v8 i was recently installing a new distributor when the oil driveshaft pulled all the way out. when i tried to replace the shaft it slipped past the oil pump hole and hopefully it is in the oil pan i am going to replace the oil pump and shaft just trying to have to eliminate taking out the engine
