Logo Automobile Information Add to Favorites  Automobile InformationLogin  Automobile InformationSign Up
Auto Repair
Auto Repair Home
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair How Does it Work
Auto Repair Automobile Safety Inspection
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Car Repair Manuals
Auto Repair Brake Replacement Guides
Auto Repair Tips Car Owners Should Know
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Definitions
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Recent Repair Topics
Auto Repair2001 Mercedes Benz 320e ...
Auto RepairMy Renault 19
Auto RepairDrive Does Not Engage
Auto RepairRenault Traffic T1100 Pr...
Auto Repair2003 Other Renault Model...
Auto Repair2004 Other Renault Model...
Auto RepairHow To Replace The Throt...
Auto Repair More Repair Topics...
Free Car Repair Advice by Professional Mechanics
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1967 Chrysler Imperial timing
Posted at Fri Sep 25, 2009 10:07 am
By supe916, Likes to hang around!
Give Feedback | Votes: 0
Engine Performance problem
1967 Chrysler Imperial V8 Two Wheel Drive Automatic 129000 miles
Hello my car has been timed and it runs worse than before valve slap and backfires outta the carb can you give me some advice in trouble shooting this also the correct timing adjustment thanks
Find a car repair manual for your Chrysler Imperial Repair Question.
Posted at Fri Sep 25, 2009 10:28 am
By Docfixit, Certified 2CarPros Master Technician
Reputation: 4955.4Reputation: 4955.4Reputation: 4955.4Reputation: 4955.4Reputation: 4955.4Reputation: 4955.4Reputation: 4955.4Reputation: 4955.4Reputation: 4955.4Reputation: 4955.4 (4955) Give Feedback | Votes: 81
Is car a 383 2bbl with points ignition?
Posted at Fri Sep 25, 2009 10:42 am
no its a 440 with a 4 barrel
Posted at Fri Sep 25, 2009 10:44 am
i have replaced points cap rotor plugs plug wires
Posted at Fri Sep 25, 2009 10:50 am
Was dwell at 30-32 degrees? if yes then can time make sure vacuum hose has NO vacuum at idle. Also make sure weights in Dist are free grab rotor you should be able to to move and it will return. Time at 4 deg ATDC these motors run better at that setting.
Pull coil wire hold 1/4 inch from intake crank good blue/white spark? Hook up vacuum guage what is vacuum ?
Posted at Mon Sep 28, 2009 12:37 pm
ok i did all that then i manually set the timing at what you said then looked at the distibutor and it was 180 degrees off so i pullled and resunk dis and no fire put it back and got fire . i have my suspitions but what is your advice i think it jumped time and im gonna have to either reset or replace timing gear chain
Posted at Mon Sep 28, 2009 12:44 pm
Well not 180 suspect engine was on exhaust stroke. pull no. 1 plug turn engine by hand. Put finger in plug hole rotate when you feel air escaping that is comp stroke. set crank on 0 TDC see where dist is pointed. If good next look at rotor turn engine counter clockwise till you see rotor move how many degs.? this will tell if chain is out
Posted at Mon Sep 28, 2009 12:49 pm
ok ill do that and just to make sure im on the right page number 1 cylinder
is on the drivers side right
Posted at Mon Sep 28, 2009 12:52 pm
Yes only Ford decided to be different and put 1 one pass side
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
Test Fuses
More Service Repairs...
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Advertise 2Carpros.com
Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l We're Hiring
Copyright © 1999 - 2010 2CarPros.com - Professional Mechanics Online
