Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Manual Ask a Car Repair Question
Auto Repair Manual Car Questions by Manufacturer
Auto Repair Talk Auto Questions by Topic
Vehicle Repair Car Repair Forum
Auto Repair Talk Car Repair Troubleshooting
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Video Series
Vehicle Repair How to Use Test Equipment
Auto Repair Manual Car Maintenance Information
Vehicle Repair Service Engine Soon Light
Vehicle Repair Car Parts and Equipment Store
Vehicle Repair How Does it Work?
Vehicle Repair Safety Inspection
Auto Repair Manual Online Car Repair Manual
Vehicle Repair Smog Test Preparation
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1985 Toyota Camry
Auto Repair2000 Mercury Cougar 60m...
Auto Repair1995 Chevy Blazer 4 Whe...
Auto Repair1995 Chevy Silverado Wo...
Auto Repair1997 Other Isuzu Models
Auto Repair1995 Ford Explorer Wont...
Auto Repair1993 Lexus Ls 400 Will ...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1966 Volkswagen Beetle steel fuel line in tunnel
Welcome to our question and answer forum where over 6,000 free auto repair questions are answered every month, after you have completed our free signup you will able to ask a question and receive an answer from one of our many forum members.
If you elect to donate any small amount of money we will assign one of our 2CarPros Certified Repair Technicians to answer your question. Questions with donations are answered promptly and 100% of the donation is awarded to the technician helping you.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Wed Feb 27, 2008 8:55 pm
By sonny66, New to the forum
Give Feedback | Votes: 0
Engine Mechanical problem
1966 Volkswagen Beetle 4 cyl Two Wheel Drive Manual 80000 miles
my 1966 bug i got someone ran a line thru inside of the bug. there the steel line that use to suppy fuel from tank back to engine. i dont know how to check the old line to see if its good or how to replce it . i dont like the idel of fuel runing in side the bug .can you help me with this ,,thanks sonny66
Find diagnostic tools, replacement parts or locate a car repair manual for your Volkswagen Beetle Repair Question.
By Advertisment,
Posted at Wed Mar 12, 2008 10:26 pm
By cognito, Tech level 1
Change the pan
Posted at Sat Jun 28, 2008 8:13 pm
By waynekarnes, New to the forum
hold on sec, hamburger thawing in microwave. be right back.
okay i'm back.
i'm no typist so bear with me.
couple years ago, dune buggy and hot vw magazine wrote a tech article with pics on how to go about replacing the fuel line.
the fuel line is metal from the rear, through the horn arm and into the tunnel. comes out under the fuel tank. metal all the way.
water and dirt, enemies of that metal line. rust forms dirt collects on the rust. more rust, eventually the line plugs.
you might try blowing compressed air through the original line or running a long piece of braided cable, like a speedo cable with a lead slug or brass tip of some sort to guide the cable around the turns and bends in the line. provided the original metal fuel line is not rusted through and the air or the cable pushes through, you may be able to use the original fuel line, with maybe a couple fuel filters in series.
the metal fuel line is attached at several different locations inside the tunnel. it will not pull nor push out.
the only way to replace it is to cut openings into the tunnel, cut loose the attachment points and pull in a new metal line using the original as a pull.
unfortunately with out a factory road map, we do not know where the line is attached to the tunnel.
the article in hot vw showed how to cut open the tunnel, where the attachments are, how to remove the attachments. how to replace the fuel line. where to reattach to the inside of the tunnel. then how to seal the holes in the tunnel.
think they said it took an expert over 16 hours to do this job. it was suggested that, with this article as a guide a skilled craftsman at home could do this in their garage. that is as long as paid close attention to the article and followed every direction.
my local shop gets 100 bucks an hour without batting an eye and customers pay it. so, 16 hours, 100 an hour. 1600 bucks.
i need to do the same on my manx dune buggy. the metal line needs to be attached inside the tunnel or it will rub and get cut through. if you don't replace and just add another metal line, cut access holes in the tunnel, drill a hole in the horn or in the rear of the pan ahead of the front trans mount.
you can then pass another metal line through the tunnel to the front. you will need to drill a hole in the tunnel under the gas tank for the line to come through.
best to carefully drain the fuel out of the tank ( disconnect the battery, both cables !!! b4 you attempt to remove the gas tank ) and remove it to access the area under the fuel tank.
it will be a Pain to run the new line through the tunnel, pushing it along, a friend at the access points guiding it.
no magic, no ez way to do this. it will be difficult and you need to be extremely careful.
if you attempt it, find that article in hot vw.
i do not know exactly how long ago they wrote it. they replaced the line with a larger one for a larger displacement engine they were running.
good luck, and remember take your time and always think safety 1st.
Posted at Sat Jun 28, 2008 8:33 pm
okay, found this on samba.
i have helped replace a fuel line on older vw was years ago. we did it the way i described above.
this person suggests a different way.
First off, ou don't need to cut any holes in your pan. If the body is still on the car you will need to remove the following items to use the existing access holes. Remove the front bumper and the front access cover in the framehead, remove the pedal assembly, shifter and inspection cover under the rear seat. Last of all you will need to remove the latge bolt at the rear of the vehicle that secures the trans bracket on the tube that the fuel line comes out of. This will allow you a hole to look in when running the new line.
Secnod, The fuel line is not welded inside the tunnel, it is held in place by 2 tabs that are bent around the tube. One is located just rear if the pedal access hole and the other is accessible thru the rear inspection hole and is where the rear frame tube is attached to the pan. You can reach the rear one with a screw driver to bend it open slightly. The front one is a little harder. I took a 4 ft long piece of 1/4 inch square steel tube, from Home Depot, and hammered the end flat. I reached through the front access hole and bent the strap open with it. Be patient.
Third. I broke off the existing fuel pipe where it exits the frame in the front and rear and used a screw driver to push the tube into the frame. Then, I worked the old tube out of the frame through the pedal access hole using a pair of channel locks and pryed against the upening to leverage the tube out the hole.
Now you have the old fuel line out. If you put a trouble light in the rear access hole facing foreward you can look into the frame from the front access hole and you will see where to route the new fuel line.
Buy a 25ft roll of 1/4 inch steel fuel line at the auto parts store. Roll it out on the floor and tape the end to keep dirt out of it. Feed it into the frame through the front opening and don't worry about getting it in the clip until the end. Once it reaches the rear insbection hole you will have to bend it slightly to guide it down the rear tube. Turn your light in the rear inspection hole to face down the rear tube and you can look in the tube throught the trans mount bolt hole. Once the tube is at the opening in the frame, use a long thin philips screw driver or any long roung object that you can fit into the fuel line. Reach into the tube with the 1/4 inch square steel piece you got at home depot, and gently lift the fuel line up towards the opening and stick the philips screw driver in thru the frame opening into the end of the fuel line. This will act as a guide for the line to follow up and out the hole. Now go back to teh front of the vehicle and push the line in and it will come out the rear hole very nicely. Push about 1 foot of extra out the rear frame hole to allow you to have extra for working the front into the hole. Do not cut the extra off yet.
Go to the front of the vehicle and cut the tube with a tube cutter, Make sure you can get your philips screw driver in the end of it so you can guide it out the frame hole like you did the rear.
Go to the rear and pull the line unti the end of the tube up front is aligned withe the hole in the frame and gently lift the line using the 1/4 inch steel tube and insert the philips screw driver in the frame opening and into the fuel line. Go to the rear and push the fuel line back into the frame and it should pop out the front hole.
Now you can adjust the tube inside the frame so it's in the straps you bent open. Use the 1/4 inch steel tube to pry the front clip back closed around the fuel line.
With your tube cutter, cut the front and rear tube so you have about 4 inches sticking out. You can adjust this length later for the perfect fit.
Place the new rubber fuel line grommets over the fuel line an into the frame holes.
Reinstall your inslection cover, trans mount bolt, front access hole and front bumper and you have a new fuel line installed just like new without cutting up you car. It took me 3 hours by myself with me car body still on my 66 very. If the pan is off the cat it's even easier.
It's not a bad job, just be patient and take your time.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
