Welcome to our question and answer forum. We answer over
6,000 free and donated auto repair questions every
month. All you have to do to ask a question is to signup
to our forum.
Asking a question is free of charge and your question
will be answered by one of our non-certified forum users
for free. You can however elect to donate to make sure
your question gets an guaranteed and professional answer
by one of our many 2carpros certified repair
technicians.
Questions
with donations are answered as promptly as possible.
Due to the nature of car repair problems, some take
longer to solve than others. We are confident that you
will be better informed regarding your problem and will
have an good idea of what direction your repair needs to
go after we have answered it. If you have donated and
were unsatisfied with our effort we will gladly return
your donation. We help thousands of people every month
and want to help you too. Sometimes it requires some
dialog between our technicians and you to get to the
bottom of your problem. 100% of the
donation is awarded to the technicians helping you.
Engine Performance problem
1965 Cadillac Deville V8 Two Wheel Drive Automatic 79,000 miles
my Cadillac blows cloudy gray smoke and, it's burning oil slowly but showly. I was told that it could be a Oil Seal or needs new heads...
Sounds like Rich A/F mixture -Burning oil-do a compression or leakdown test to find out where its leaking at.
oil leaking could be a seal, try valve cover gaskets first start at the top
burning oil could be valve stem seals or stuck oil rings, with the valve covers off you can change the valve stem seals if you know how, you need a air compressor and a valve spring compressor, I would start there
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
