Auto Repair Talk - Ask a Question, Get a Free Answer
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1963 Dodge Dart starting engine
Posted at Sat Oct 10, 2009 6:54 pm |
By
jeff wooten,
New to the forum |
Give Feedback | Votes: 0 |
Engine Performance problem
1963 Dodge Dart 6 cyl Two Wheel Drive Automatic
my 63 dodge dart has idle for over 3 yrs, when I tried to start it,(pour some gas in the carb.) the engine crank over but it would not stay on. It has gas in the tank,but is not flowing to the carb. Could it the fuel pump? If it is how do I test it? or is it something else? |
Find a
car repair manual for your Dodge Dart Repair Question.
Posted at Wed Nov 04, 2009 8:29 am |
By
two66mhz,
Likes to hang around! |
(12) Give Feedback | Votes: 0 |
| jeff wooten wrote: | Engine Performance problem
I could be the fuel pump, it could also be the carb need a good cleaning too. If it sat (i assume, check you spelling) for that long with fuel in the floats it could have a nasty coating on it. Carb rebuild kits are cheap and are not that hard to do. The fuel pumps for you car are rather inexpensive too. Also your fuel filter could be clogged or lines hard to tell from here.
If you have a fuel pressure gauge hook it up and check to make sure you have close to 8 psi (if I remember correctly).
Best of luck |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
