I have a 2001 BMW X5, 4.4i with 60,000 miles. I recently replaced the alternator. Two days later, I got into the car and started the engine...all was normal except that my environmental control panel indicated the AC was blowing FULL but there was no air from the vents. The compressor was working, and the rear fan was working and cooling. I removed two 7.5 amp AC fuses and they were good. The 50A main blower fuse is good. There is one interesting factor.. I pulled one of the 7.5A ac fuses with engine running to verify it was correct fuse (compressor stopped) and when I replaced it the main fan started working. However, when I moved the car it stopped. It came back on once about 30 seconds later then stopped. Do you have any ideas about this issuue? Thanks JP
