Fuel Pump and Pressure Regulator Test Video
Testing Fuel Pressure Video
This video contains basic a testing procedure using an automotive fuel pressure gauge as a detection tool to test a fuel pump and regulator. Correct fuel pressure and fuel pressure regulator operation is essential for your car's engine to operate properly. Many engine run-ability problems can be related to a weak or failing fuel pump or regulator. Problems can range from hard cold engine starting, low power and stalling while driving.
Most cars have a fuel system test port designed into the fuel rail. If your car doesn't have a test port a fuel filter adapter port is needed. This port is attached to the feed side of the fuel filter and then removed after the test is complete.
If further assistance is needed, our certified car repair technicians are ready to answer your car questions.
Related Car Repair Information
