2CarPros - Car Questions & Answers
Replace Front Pads and Rotors Video FWD
How to Replace Front Brake Pads and Rotors
Replacing brake discs can vary depending on the make and model of car, two wheel or four wheel drive, front or rear wheel drive. Always replace brake rotors with top quality or OEM (original equipment manufacturer) brake rotors, some less expensive brake rotors can squeak and not dissipate heat as well because of their inferior metal quality.
The following video shows step by step how to replace front brake pads and rotors on a front wheel drive car. To replace brake pads on your car might be slightly different and there could be a couple different ways to achieve the same operation.
